I found a bunch of links to Cummins data sheets. The data is summarized in the table below. Links are provided.
NOTE: B3.3 and QSB3.3 engines have can be ordered with SAE# 3 or SAE# 4 flywheel housings
Cummins turbo engine measurement table:
........................B3.3.................QSB3.3.............B3.9.................B5.9
Advertised HP....75-85...............90-110.............110-125...........150-173
Peak Torque......193-215............274-304...........346-373............453-580
Length (inch)....28.1..................27.7.................30.6.................40.0
Width (inch)......21.9.................24.3.................24.6.................24.9
Height (inch).....31.4.................29.9.................37.7.................37.9
Weight (dry).....553 lbs.............585 LB
Weight (wet)....................................................745-782 LB.......952-997 LB
# of cylinders....4......................4......................4......................6
Links:
B3.3:
www.cummins-sp.com/document_library/Spec_Sheets/Engines/Industrial/B3-3_Spec Sheet.pdf
www.cummins-sp.com/document_library/Brochures/Engines/Industrail/3624649 B3-3 Brochure.pdf
QSB3.3:
www.everytime.cummins.com/assets/pdf/4087118.pdf
B3.9:
B5.9:
www.everytime.cummins.com/assets/pdf/4087025.pdf
Phoenix Casting for adapters:
www.phxgrp.com
Russ
Links:
B3.3:
QSB3.3:
B3.9:
B5.9:
www.phxgrp.com
Russ
