Yet you're perfectly fine comparing two completely different vehicles with completely different drivetrains
Massive amount? There are 28 trucks in the 1996 data. The rest have less. You cannot "guarantee" anything about gearing since nobody specifies their drivetrain. The highest probablility suggests they are largely stock, and many may have larger than stock tires which negatively impacts fuel economy. Were the trucks empty or loaded? City, highway, or mixed. Driving style?
The high (or even mid) 20's are not in heavy venicles. If they are, well, I will be polite and call the data
extremely suspect.
There are a couple on the first page alone that I can compare my vehicle to. The first is in
post 15:
Here's
another one:
This guy lives in the same town I do, and that trip is similar to trips I take (although I am usually loaded heavier). Neither of those vehicles do much better than mine.
Yes I'm perfectly fine comparing two pickups of similar dimensions driven by the same guy in the same way. As I've said many times already they are the best results we have. Far from perfect, but still the best we have.
The fuelly data is 63 vehicles, 1997 data alone has 253 fill-ups, so it's an excellent sample size which I'd expect to cover the spectrum of vehicle use. Feel free to drill down through the data to individual vehicles and fill-ups for a check.
So you're good with 6BT's reporting 22mpg, but it's extremely suspect for a 4BT to report mid to high? That's some bias you've got there. It's perfectly okay to have a favourite engine. But you've got to realise that it's not the perfect engine for everyone else.
Yes there are genuine 30+MPG reports in there. This is what they have in common:
2wd vehicles which sit low to the ground.
Street tyres or tall and skinny ones pumped up hard.
Relatively high gearing.
Driven long distances at moderate speeds.
Don't expect anyone with 33" mud tyres in a taller 4wd to get respectable MPG. All that noise and wear the tyres suffer is energy wasted. Plus the aerodynamic losses, which alone make or break decent fuel economy.
That said, one of the Power Wagon owners did a genuine 30mpg run. But at quite low speed.
My personal best for the 4BD1T is around 8.6 litres/100km (27.3 USMPG) in a full-time 4wd with A/T tyres while cruising with summer holiday traffic on a route with rolling hills.
But even this result is poor compared to the exact same vehicle factory fitted with a smaller engine (300tdi) with less power which turns faster (2500rpm at 100km/h).
what are you using to back the guarantee? third hand info?
you are using Lonno's trucks as a valid comparison, but they dont even have a similar drivetrain. 4bt is ve pumped. the 6bt is p-pumped. we all know the inline pump will hurt mileage compared to the ve just because of the static timing. these are completely invalid comparisons. both are modified in some way. that makes the comparison moot again. the same reason why dieseldudes trucks are not a for sure comparison either. they are close to the same, and i would take that as more valid comparison, but without knowing the build on both rigs and what they are it is just speculation as to why or what causes the difference.
this is why i question calling into view the data on an 4bd1-t info and NPS chassis. its like comparing a 5.0 mustang to a 5.0 camaro. one is a roach and the other works well. just because they are similar in size doesnt make them a good comparison. if we are going to the effort of calling technical data up to back an argument it needs to be technical data for the engine in question or it certainly cant be taken as evidence for one side or the other. it is just circumstantial.
agreed. this is why the question i ask is what is the absolute restriction on the build, happiness with end result or fuel economy, and what circumstance is that economy value going to be in question.
that converted camper rig is sweet. needs a desert tan paint job and it would be perfect.
that sketchy bearded dude is a notorious hack and a liar! haha.
while still third hand info, i know this guy as well. he has no reason to lie about the performance of his burb. he doesnt care what any of us think. it is one of the best conversions i have ever looked at. everything is well executed and top quality. there is no need to question his results. he is more than intelligent enough to do the mileage calcs and like i said, he doesnt give a poop if we believe him so he isnt going to lie.
i wonder what the difference would be on his burb after the turbo swap? i would bet if he ran that trip again now that the turbo is more efficient he could do a little better.
regardless of any of this, i think we can all agree that on a test stand the 4bt will win the consumption argument. if the 6 was going to be more efficient, would they have even made the 4? the differences will come from application and driver. so if the absolute bottom line is fuel consumption, put the 4 in it. just make sure it is set up to be efficient. if the same variables that we all have to consider when building a custom apply to this build as well, then there are more questions to be asked of the OP and more info needed.
Out of a sample of 63 pickups I'm quite confident I'd find trucks with raised gearing. Through regears or just bigger tyres. The effect is the same.
How many kw in drive power do you think it takes to run a ve pump vs p pump?
The 4BT motoring friction I've been quoting is for an A pump 4BT. Comparable drive power to a P pump. The fixed timing hindering efficiency is only a problem with P pumps at higher rpm. At cruising rpm (where fuel economy is made or lost) they are timed correctly.
Put two different drivers in the same vehicle over the same route and they'll get different fuel economy. You can see 20% difference from driver alone.
Throw in the vehicles being driven in completely different places and comparisons get tenuous.
Then we're into fuel economy reporting.
Some people round off the miles, round off the gallons and do the maths in their head. Good enough for their purposes.
Some people calculate the occasional trip or fill-up. Too much hassle to do it all the time.
Some people calculate every fill up but never bother to average.
Some people keep a complete log and calibrate odometers to make sure their records are correct.
As you can imagine, there can be significant differences in reported MPG for what should be exactly the same data. There can also be wildly different data coming in and the same MPG being reported at the end.
This is why Fuelly is good. It's a running log for each vehicle. Only really good for stockers though.
The newer NPR/NPS expedition builds are much more impressive. That was the only example I could find on the net of a camper body on a pre 94 factory fitted with the 4BD1T. Mitsubishi do a comparable Fuso with similar sized engine.
I've had 3 6bt powered 3/4 ton trucks that averaged over 20-22mpg. If a full size truck is only getting 25 with a 4b I cannot see any reason to use one.
Was it 20 or 22mpg? There's 10% difference right there.
25MPG vs 20MPG is a 25% improvement.
In a vehicle that goes a long way from fuel stations that 25% greater touring range can be extremely important.
In a vehicle that's used only occasionally and never strays far from paved roads it's unlikely to ever be a problem.
