Cummins R2.8 Turbo Diesel crate engine
2 reading
14K views 33 replies 9 participants last post by  scout4bta
#1 ·
Is the Cummins R2.8 Turbo Diesel crate engine too small for a 1 ton 4x4 swap? I would like to use a manual transmission. I would like to be able to do 75 and on the highway, thinking with 3.55 gears and 21 inch or greater tires.
#33 ·
Scout, your measure sounds about right. The bare engine block is 29.45" long. The flywheel housing is probably nested under the firewall. The fan and fan hub assembly is all out front. With 38" there couldn't be a lot of room between the fan blade and the radiator. A tight squeeze. When they added the intercooler in '91.5 the fan hub got shorter. That was as compact as a 6bt got.
#34 ·
I took the measurements off of my 91.5 and my wife's 94. The measurements are plus/minus 1/2"?
In both trucks the engine is about 1" from the firewall as far as i can measure, and the fan clearance is about 1.5" to the radiator. These measurements do not account for the charge air cooler.
